Tailgate Window Motor Replacement
My window won't even go down now. It'll just click when I apply the switch. I know my battery's days are numbered, but my two door windows go down. I turned the regulator cable with a drill, and the window rolls down fine. The only reason I posted is because it looks like the motor may have been replaced before. It is relatively shiny and it has two orange dots painted on it. I was just wondering if I missed something and don't need to fool with the motor yet. The regulator seems fine, the drive cable is turning... I have yet to see that twelve volts are getting to the motor on the up and down side, but I'm assuming yes because the window was just super slow when I got it. Any thoughts on the matter are appreciated.
yevgenievich
Place
Name
Year
Model
Size
Check for power and see if the window was binding somewhere causing motor to die. There are also instructions floating around on how to adjust the window correctly
gmachinz
Harnessworx Inc
Iowa
Jabin
Verify the tailgate has a good ground. Typically (and with rusty K5 gates) the ground circuit faces a LOT of resistance and those motors are a self grounding type meaning your dash switch only applies +12V in either direction-the motor casing is grounded by being bolted to the gate which is chassis grounded to the truck via the attaching hardware.
acesolis
