Turbo4whl
- Oct 30, 2019
- Downingtown, PA
- Wayne
- Jimmy
So what do you guys think about the tail lamps? Could it be the switch? Or a ground? I don't know how it'd be anything else but the switch if the brake lights and turn signals work. Is there a way to test the switch?
Earlier you said you replaced the burnt brake/turn lamp fuse. Did you check the parking light fuse?
