Switch panel?
BigSherwood
Malone ny
suburban
Does anyone know of a good place to mount a switch panel in these squarebodys i was hoping to find a overhead console or something of the sort or knock out one of the heater vents to put one there but i was looking for ideas of places to put them
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
I put a switch panel in a center console that I made. Ran the wiring under the carpet to the switches. Fit pretty good between the transfer case shifter and the bottom of the dash.
Have also seen guys replace the ash tray with a small set of switches too.
redneck_reed78
Spring Valley WI
Braden
R30, Suburban
I've got a rear locker switch, and a fan switch in the rear corners of the cab, along with my speakers. I just spray painted plywood and mounted everything up. I figured I'd do that so that everything looks as stock as possible, and so I don't have anything cut up in the dash. It works pretty good, I just have to finish securing them yet. I'll attach a picture later.
twzorek
