Suburban front end
85 C10
Buaffalo NY
Jason
I am thinking of adding the front grille lights from the 90 - 91 GMC suburban to the front of my 85 Silverado. How much work does this entail? Also thinking of shaving the drip rails. how hard would this be. thank you all for the help hope to start posting pics of my baby this season
You have to change the core support then the Mini Quad grill and lights will bolt in. So get the core support from the donor that has the Min Quad Grill. Prolly ought to get the wiring harness too then you can adapt it to your current harness real easy.
Why shave the drip rails??? They're screwed on. Unscrews the screws, take them off and fill the screw holes and finish with your favorite paint method.
Hoodbj
Billy
R10
Hot rods exactly right, look for a loaded core support. I recently did this on my. 87 swb and it's pretty straight forward. The core support bolts to both fenders, two that if I remember correctly bolt to the frame through those big rubber supports. Make sure you grab the harness that goes to the new headlights as the connector is different. Another thing to look for is if you have an oil cooler on your old support. I believe my old core support also had the charcoal canister bracket on the inside of the support and the mini did not. I relocated it to the inner fender well. All in all it was a pretty quick swap.
bmfp407
fl
brett
r20
sounds easy enough
