Suburban Dash Rear AC switch
Brian Bonehill
Dallas
Suburban
My 86 Burb had a short in the rear AC switch on the dash. (The one that is hi / low / off, black rocker switch). I want to get a new one as I upgrade the system. I cannot find one for the life of me. Does anyone have a link to one? Thanks.
saltdog
US
K20 Suburban
@Daddyscaddy To use, you will need to cut off the factory plug connector and use individual insulated disconnects on each wire (2, 12 AWG and 1, 16 AWG). Each row of switch terminals is separate they do not interconnect electrically - so just use one row (ie 1,2,3). Grey hot wire to center term 2, low (yellow) and high (Orange) wires can go to each side 1 and 3. The Grey wire is from Bat fused at 20 Amps in the panel, Orange is load to fan, yellow to resistor in evaporator case. High does not use resistor
77Heavyhalf
