Stock 350 with SM465 4speed
C10Big10
WA
Ryan
SBC350
Looking to replace clutch/flywheel
Never attempted before
Looking for any advice suggestions on clutch kits or how to info.
Motor is stock. Nothing fancy. Just need to be functional
Thank you
CountKrunk
SW VA
Count
C20 Custom Deluxe 3+3
v8 350
Probably is on YT
77Dmax
vt
Joe
No need to replace the flywheel, it can.be resurfaced at any machine shop.
It's pretty straightforward, drop the trans and send it.
Resurfacing should work fine, but make sure you look for cracks first.
  • Like
Reactions: WFO
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
We always resurfaced the flywheel. Have to pull the shift handle and clutch linkage and a wire or two if they're still there, speedo cable, and driveshaft.
Pull entire transmission including bell housing. Do a throwout bearing now too, even if it seems decent.
Nborden88
