Steering Column Upper Bearing Assembly
sonicbluezx3
North Carolina
Steven
So I went to replace the ignition lock cylinder in my 78 K5 Blazer.... got it all apart, replaced what I needed to replace, but then I noticed the little ball bearings coming out. I put them back in the little plastic piece but after I got it all back together I noticed there were 3 of them that came back out. I didn't use any grease to hold them in so I think that's my issue, but I could be wrong. The housing may be worn, I'm not sure.
SO two questions....
1) Assuming the bearing can't be reassembled with grease, does anyone know where to get a replacement bearing assembly? Or even a part number, or technical name for it? I tried upper bearing for a steering column and haven't seen much.
2) What kind of grease do I need to use?
da_raabi
Trailer Park Supervisor
FloriDUH
Adam
c30
I had a similar problem with the column in my Camaro, except that the plastic housing broke. I super-glued the housing back together and just used some general-purpose grease I had and stuck the balls back in. I haven't used the column since then as it is for a long-term project, but it seemed to work and I see no reason why it wouldn't. If the grease was good enough for a wheel bearing I figure it should be good enough for this!
MadOgre
NA
NA
NA
NA
NA
yes you need to be generous with the grease
