Steady 5.5psi fuel pressure drops when warmed up
Old Guy Bill
KY
Bill
The three factory style pumps with return ports I bought all fluctuated badly at idle, the one I went with lasted a month.
Put on an Edelbrock pump without a bypass and its supplies a steady 6 lbs.
It's been on almost a year.
andybflo
Western NY
Andrew
C-10 Silverado
5.3 LM7/4L60E
Absolutely normal on a liquid filled gauge.
They're usually only accurate cold. Early in my years of building cars with Mallory electric pumps, I chased the same non-issue.
You'd know if your FP fell that significantly. Don't believe the gauge. The truck is telling you it's fine. Believe it.
elbpony
Germany
Tim
C10 Custom Fleetside
350cui 4BBL
I'll take the regulator out the line for a test and see how that changes or not changes. It runs perfect everytime and I am getting used to the uncomfort every Mile made
The Right side of Washington
In short, I’ve never given a second thought as to putting a pressure regulator on a mechanical fuel pump system. Regardless of vehicle mfg, carburetor brand or brand of fuel pump.
Maybe there is a mechanical Chevy fuel pump that can blow the needle or seals on a carb but I haven’t encountered it.
Conejo_K10
So. Calif
Pete
I don't have a regulator on my K10 but do have one on my classic car. I noticed the pressure was ~9 psi cold and then dropped to 4.5 psi warm.
Most carbs want 4-6psi. At a higher pressure the float valve may be unseated dumping extra fuel into the intake.
Basic mechanical fuel pumps aren't that precise.
77Dmax
vt
Joe
You need an isolator to get a proper pressure reading when dealing with such a low PSI. You're probably fine, as mentioned once the gauge is hot it's no longer accurate.
Camar068
Air Force Supporting Member
Kentucky
10 yrs Air Force
3-4.5 psi is what the eddie's like regardless of what the directions say.....if your's is like a 1406. Verified by a phone call to them....long time ago lol. Quick call to them to discuss. Off the phone in less than 5 minutes.
anjones98
