starting in gear
john55
illinois
john
i was starting my truck wasn't quite in park. it tried to start, so i checked it, in other gears the same thing. does this have anything to due w/ the brake light /turn signal issue in the below thread.? thanks .. also what's you favorite sq bd manual ?
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
Sounds like your neutral safety switch is out of adjustment, or is worn out to the point where there are metal shavings inside, making contact throughout the gear range.
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
i bypass the neutral safty switch in my manual tranny trucks
i have used the starter to move my trucks short distances when they broke down and to start out when i had clutch problems.
and i have it bypassed on a couple of my auto trucks as well it quit working in my 71 i had to bypass it.
its not a big deal as long as you are aware of it and have a good head on your shoulders
It's been bypassed in my '79 too. Really, the safety switch isn't needed if you know how to drive, IMHO. I put a floor shifter in the Burb, so there's no functioning safety switch and there's not even a gear indicator... even my wife can drive that thing everyday without any trouble at all.
KAR1130
