Stalling going uphill
cstew47
colombia
craig
This is a problem that I thought had been fixed. My K5 started stalling out on steeper hills. I had just rebuilt the carb (1405 EDLEBROCK) and it seemed ok, even on normal hills. Lately, I encountered some steeper hills and the engine stalled out. The carb floats are all set to the correct tolerances. I suspect fuel flow problems. My engine is a 383. My fuel pressure is running about 8 psi and I know the carb wants 5-6. I am going to install a regulator with the hope that will solve the problem. I am also wondering if the fuel pump may not be producing enough flow. It's a standard pump so it's probably only flowing at 40 gph. Maybe a 110gph pump will help. Anybody have suggestions or solved similar problems?
standard should be fine. do you have a return fuel pump? and is it an aftermarket? have you blown the lines out, checked the tank sock?
Camar068
Kentucky
10 yrs Air Force
weren't the Edelbrocks prone to steep incline issues? I don't know what degree "steep" would be, just something I've read. I'm sure someone knows and can clarify. Who knows...I may be way off in left field lol.
