Staineless Long Tube Headers
GunMan9
Yorktown
Brandon
Do I have to change the exhaust pipes installing these? Also what are the advantage of them? Some guy on craigslist has them for sale for $100. Good deal?
Swims350
Logan WV
none
if they are stainless or ceramic coated yes good deal, painted NO not good deal.
if in deed they are long tubes and you don't already have long tubes now then es be prepared to rework the front exhaust.
what does that mean? you need to move or modify the y-pipe if you have one or do away with it, reducers on the pipes, cutting welding, bend work etc.
GunMan9
Yorktown
Brandon
so its not worth it to do... Since I do not have all the tools to do the conversion.
Swims350
Logan WV
none
it's worth it, and why do it yourself? have a local shop do the exhaust for you, or buy a bolt on kit that uses clamps.
Boondock
North Carolina
350 cu. in. (5.7L)
I'd be on that like white on rice if I were you. Local shops don't cost that much around here for exhaust systems, unless you have those damned censors. :| Thank God mine doesn't have that emissions crap. DEATH TO THE ENVIRONMENT. :) Haha.
