Squishy brakes
Ricko1966, You should have let it go back in the thread on post #14 like you said you were going to do. IMO you started out in a bad mood. I hope you get over it soon.
Squishy brakes fixed.Well I got a chance to talk to O.P.,it was a pedal ratio problem,he relocated the pushrod and problem solved. So I guess it's a good thing I didn't stop at post 14. Anyway squishy brakes fixed brake pedal ratio problem when adding power brakes to a non power brake vehicle,relocating brake pedal pushrod fixed the problem. I think I got enough key words in this post that the next guy using the search engine will get a hit.
UNCLECHAD2021
