Squeaky and leaky brakes/pedal
77chevy400
Eastern NC
6.6l (400)
On my 77 previous owner sent 2 wheel cylinders with the truck. I have looked at the rear right so far and i noticed behind the rubber sleeve it looks just a tad bit wet there. And according to what ive been told in the back if a wheel cylinder is bad it'll show signs like squealing brakes(pads are new). And itll leak fluid under the end sleeve.
Thats my major issue because its obnoxiousoy loud.
However if im sitting on a incline my brake pedal will leak down. After i depress it further after the 2-3 time it leaks down truck rolls forward and you CAN NOT stop it with the brake pedal.
It leaves me with two options slam it in park or use the emergency brake.
I checked the connection on the brake booster vacuum line. Its a new piece. So im thinking its a internal seal in the master cylinder. Which woupd be easier and cheaper to replace rather than rebuild.
Ive also. Checked the brake lines..no leaks. Resevior stays full so it mist be a air leak.
Any insight.
Sent from my Reddot R50 using Tapatalk
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
I would start with a master cylinder.
highdesertrange
kalifornia
mike
k30
drum brakes don't squeal, they might grind or get the harmonic vibration noise like semi's do. if you have fluid behind the dust boot that cylinder is getting ready to go bad. however from the sound of it you have a bad master too. highdesertranger
77chevy400
Eastern NC
6.6l (400)
What happens if the cylinder goes bad. Im getting sure the squealing up front occasionally is brake pads because if it squeals and i push it harder itll stop.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
if the wheel cylinder goes bad it will puke out the brake fluid and you will lose your brakes.
imyourhuckberry
