no slack
- Feb 26, 2013
- Georgia
- Antonio
- c10
- 5.7 350 TBI
ok I have a truck thats a part of two trucks the cab is from a 1981 with non auto windows and locks. The rest of the fram is from a 1987 with TBI the motor put in is from a 1995 chevy 1500 TBI now thats out the way this is what im writing about the 1995 motor has two sensor I can see from under the hood one ont the driver side of the block and one on the intake close to the water hoes the ignition coil plug also has a connection for a sensor the wire harness from the 1987 has a connection that seems to be for the sensor close to the water hoes and a connection that fits the sensor on the side of the block all the other connections seem to be missing on the wall behind the motor I can see a plug that has PED 40 on it that is not connected to anything the gagues dont work on the truck oil, temp. when I connect a 20 gage fuse in the fuse spot under the steering wheel it blowaI would like to have everything working normal whats the best thing to do to make this happen I have no idea what way to go
