SOLD 1987 k10 suburban for Parts *All Gone*
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Would you have the vacuum brake booster push rod that mounts between the brake pedal and booster under the dash? I'm switching from hydro-boost to vacuum boost.
Damnit somehow I overlooked this, yes I still do.
Vbb199
Salisbury NC
Vince
Just wanting to bump this back up, I've kinda forgotten I had it, I still have a mostly complete 5.7 tbi motor, v belt drive. AC, Alt, ps pump and 4x4 box, also has a smog pump.
Motor has just had a few odds and ends taken from it I needed, mainly vacuum lines.
I still have the aftermarket Jacob's ignition system.
Body is mostly a hull, but I still have all the AC stuff from the firewall, some trim and interior goodies, brackets, and such. Here and there I'm working on cutting **** I need off of it.
Truck has a decent skid on the gas tank I removed, 41g tank.
Just ASK! And I can get more crap shipped away.
I have no use for mostly whats left.
Ok hood, surface rust, still have rad support.
Oil and tranny cooler are gone.
Trans and t case are gone.
Axles gone.
Doors, seats, headliner, and alot of. Plastic trim is gone.
Cluster, column, and cluster bezel are gone.
Tailgate has been pillaged, but I still have the shell, it's a 4/10 maybe.
Cab lights I've taken, as well as cut out the roof section they were at to use as a transfer template.
Contact me! Let me know what you need!
There's still some decent stuff.
PM me or text me at 704-738-8300.
If you insist on calling (which is OK)
Leave me a clear voicemail and let me. Know who you are! :)
custodian
Catawba
William
5.3 LS, 350
If it's what I think it is, it's just a little thing correct?
It's the rod that screws onto the push rod on the back of the brake booster and has a round mounting hole that mount to the brake pedal. Around 6" or less. Used for adjustment.
It will look like the one pictured.
Vbb199
Salisbury NC
Vince
Dis? o_O
Vbb199
Salisbury NC
Vince
@bucket @HotRodPC
Can One of you guys mark this as ... uh.... sold? Idk
The little bit that's left is headed to the scrap yard this weekend. All that remains is the frame, and I'm keeping that
@bucket @HotRodPC
Title changed to SOLD
dougli1
