Sniper fuel pump with existing EFI pumps
Joe1shoe
Wernersville
Joe
Truck us 1987 GM PU. Dual Tanks. I removed the TBI Carb and ECM some time ago for a classic carb. I want to install a Sniper EFI Carb. I have existing EFI pumps that run continuously with ignition on to a regulator for the carb and return line. The Sniper Master kit has an inline HP fuel pump. I doubt it will pull fuel through the existing pump if they do not run.
Can I use the blue wire from the sniper EFI to the original fuel relay, AND to the Sniper fuel pump to control fuel flow? The original pump runs when the sniper pump runs?
Replacing the original tanks or in tank pumps is a lot of expense I'd prefer to avoid.
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
Sniper needs 58 psi. Your TBI electric pumps aren’t much over 10 psi. I don’t know that running the in tank pumps to an external high pressure pump would work well.
If you don’t want to drop your tanks and put a pump like an ACDelco ep381 in, your best bet is a sump system. These are fed by your existing pump, then turn that low pressure into high pressure with a submerged pump in the engine compartment.
By the way, the correct in tank pumps that will work with the sniper aren’t expensive. They’re somewhere around $50. They replace the pump you have in your tanks and it’s super simple. With two tanks, you have a switching valve and that will need replacing due to the increased pressure. Again, maybe the easiest for you is the sump system.
As for running the high pressure pump off of your existing relay: the sniper harness has a built in relay with a 12ga blue wire that you run directly to whatever high pressure system you choose.
75gmck25
Northern Virginia
Bruce
As mentioned, you can buy fuel sump or surge tank systems from Edelbrock and other places, and they are about $400. You connect your low pressure line as input to the reservoir, and the built in pump jacks the pressure up for your EFI. The small tank mounts in the engine compartment and the pump is activated by the EFI. I like this solution because I can leave all my existing dual tank setup as factory.
Surge tanks are also common for racing if you have issues with the in-tank pump sucking air during high speed turns, so there are many articles on how to build your own.
Bruce
SquareRoot
I have a Edelbrock remote tank in my 85 k20. Its fed from the factory mechanical pump around 5-6 psi. It works great except I've recently discovered it doesn't like the engine compartment heat. I never had an issue until summer when outside temps got up around 95 and higher.
It will be coming out and done correctly with baffled tanks and in tank high pressure pumps. If I would have done it right the first time I would be time and money ahead.
Joe1shoe
Wernersville
Joe
Thanks for the advise. I’m going to try feeding the new pump with the factory pumps. It that does not work. I’ll replace the factory pumps with Walbro 5CA400HP Direct-Fit Fuel Pump Kit 255 LPH GM In-Tank.
Texxxan
Hooks, TX
Jose
Just curious if it worked.
Joe1shoe
Wernersville
Joe
It does look like it worked. We have it up and running. We drove it 4 times for the learning process.
BUT...... I'm not ready to recommend this just yet.
I could use some further guidance on this. when I used the stock TBI pump to the Sniper pump (connected after the fuel valve) the pressure was too high. I was getting around 100psi. So I removed the original fuel relay so the tank pump would not run. The sniper pump does pull the fuel. But I can't switch tanks. Can someone tell me how to power the Fuel switching valve via the fuel switch in the cab without energizing the pumps? And if the tank pump does not work will the fuel gauge work?
Marcoman
California
Marco
Scottsdale
Hey, can you give us an update on your EFI dilemma?
Joe1shoe
Wernersville
Joe
Ok. Here is the update. The tank switch problem was the switching valve. Replaced it and my tanks switch. The Holley pump is connected about 4” after the valve. I do not run the in tank stock pumps. I do get a consistent 61 psi at an inline gauge. I drove it on 2 hour trip and back and did not have an issue.
I’ll say the pump is on the noisy side as others have said. I can hear it in the cab while still but not while driving. But the truck is not exactly quiet. I could hear the original pumps at ignition but not while running. Many comments that the noise is due to some cavitation. I cannot prove or disprove that.
I’ll also say that my install is not officially sanctioned by Holley. They recommend replacing the tank pumps with approved pumps.
Todd Lemon
