Sm465 locked up in granny gear
Shorty81
Baby Boomer
North West ohio
Darren
I parked my truck at my local Wal-Mart. Before I shut it off I put it in low first like I always do. When I returned and tried to leave I could not get out of first gear. I was running out of time so I left it at a friend's house. I have had many 465's but never had one stick in first. Going to pull the shifter out tomorrow. Any ideas??
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
No ideas sorry but you are going about it right starting with the shifter. Hopefully you will find the issue in this.
Jrgunn5150
Questionable methods
Ionia Mi
J.R.
6.slow
I've had to pull the shifter and use a screwdrive to line the slots up, then re-install the shifter before. I was young, poor, and dumb back then, so I never figured out what was causing it, but I must have had to do it three or four times in 2 years
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
The roll pins holding the shifter in the top cover may be slopped out and out of place causing a bind. The actual coupling assembly of it that drops into the cover may be slopped out as well, the handle itself may need some tlc also.
Shorty81
Baby Boomer
North West ohio
Darren
Thanks for the help fellas, I will find out today.....
73c20jim
Tombstone, AZ
I was told never leave your manual trans in gear when you park it. Someone might bump into you and cause it a problem.
Following and waiting for cause.
Hope its something simple.
idahovette
Weiser Idaho
Perry
K20-K10
That would mandate an emergency brake or carrying blocks to keep it from rolling away. Some of us don't have an efficient e-brake that works or that is trustworthy although we should repair it!
Madhorn
AR-Arkansas
Ken
5.3/NV4500/NP205/4:56 gear/35in tires
I agree the parking brake can be untrust worthy. Right or wrong, I have always put my manual transmissions in reverse when parking.
Some cars back in the 80's, you had to have it in reverse just to get the key out of the ignition.
73c20jim
Tombstone, AZ
this i remember
73c20jim
Tombstone, AZ
I never paid attention to this. Always used both.
Just throwing it out there.
Shorty81
Baby Boomer
North West ohio
Darren
Update: I pulled the shifter out and slid the the right linkage forward and inserted the shifter and everything worked fine. I could not find any wear on the roll pins or shifter or detents. A fluke maybe??
Jrgunn5150
Ionia Mi
J.R.
6.slow
Like I said, I had one that did that every so often. I never got to the bottom of why. I'm sure there was something wrong, but I never knew lol.
Customblue
Locust Grove, Va
Brandon
Is the end of your shifter worn down? I've seen it where the driver constantly held his hand on the shifter while driving, it creates extra wear on the shifter end that contacts the shift forks and the shift forks themselves. Novak makes a solid shifter which is really nice. You feel more vibration but tighter, positive shifts wir bu out the rubber piece
Shorty81
Baby Boomer
North West ohio
Darren
The dog on the end of the shifter looks like new, showing no wear. Everything feels right and has always shifted fine.
Hard
