SM465 Fluid Capacity????
OkieFishMan
Certified Camping and Fishing Nut
Enid, OK
OkieFishMan
GMC C2500
454/SM465
Does anyone know the fluid capacity of the SM465 tranny????
Cuba
Likes to work alone in her woman cave
Philly, PA USA
Cuba
S10 Blazer
4.3ltr TBI
I think it's 4 quarts or slightly over. Definitely less than 5, but I think less than 4.5 too. It's a little PITA to do on these too... at least refilling.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Pretty sure you just wanna fill it up until it runs out of the fill hole.
CSFJ
Is the 465 the one that you need to be carefull to get the actual fill plug, because there's a threaded cap holding a cross shaft or something in? Or am I thinking of a different trans?
Jrgunn5150
Questionable methods
Ionia Mi
J.R.
6.slow
No, I fill them through the shifter hole until it runs out the check hole, takes about 4 quarts usually.
CSFJ
I know they can be filled through the top, I can't recall what trans I'm thinking of that had a threaded plug, that held something in place that looked like a fill plug. It may have been a jeep trans, now that I think of it more.
Oldrider
NC
k2500
I believe close to 4 quarts. I fill through the check hole in the side.
