Sloppy Window Crank Handle?
CRM
Pasco, Washington
Casey
K2500
350 CI
It was driving me crazy because the existing piece of rubber had shrunk a little over the years. So here's the solution: A little foam weatherstripping with tape on one side.
highdesertrange
kalifornia
mike
k30
that foam piece is meant to stop drafts, not to make the handle tighter. if your handle is sloppy it's probably worn out or it's a cheap Chinese replacement. highdesertranger
CRM
Pasco, Washington
Casey
K2500
350 CI
Sure worked for me.
Camar068
10 yrs Air Force
mine is the cheap chinese.....can't even put a clip on it. Might be the assembly instead of the handle though. the 2 just don't line up. I prolly could take a dremel to the handle and make it work. Other things on the brain.
74 Shortbed
Yep, the foam is to stop the draft and it puts pressure against the handle so it don't rattle around, but if it's one of them China junk handles don't be surprised one day when you hit a bump or pot hole and the handle pops off and falls on the floor, LOL..
highdesertrange
kalifornia
mike
k30
I am just telling you what the foam is for. if you want to make it into something it's not, to take up slop that's your business. if it were me I would fix the problem and not mickey mouse it. highdesertranger
CRM
Pasco, Washington
Casey
K2500
350 CI
It very well could be a cheap Chinese product, but there was a gap of about 3/16" between the washer and the door panel. Once the extra weatherstripping was installed the gap was gone and the handle/washer no longer had any sloppiness. I can only afford so much when I'm the sole wage earner in the family.
CRM
Pasco, Washington
Casey
K2500
350 CI
Decided to go by "you pull it" to look for sun visors and guess what I found? All metal..1974 Burb.
74 Shortbed
Nice find..
Rusty Nail
Rusty
350sbc
Glitch in the MATRIX, haha!
I love when that happens...
Camar068
10 yrs Air Force
update: didn't have to do anything, just had to hold my tongue just right and lift a leg and fart and burp at the same time. BAM it slid right on there.
74 Shortbed
87ChevyR10
Kansas
NA
NA
NA
LOL! THAT'S WHAT SHE SAID!!!!
:sorry: :party36: :)
EDIT: To be fair, the topic title is screaming for Viagra...
Bhardiman1
