Slave
Smitch320
The Southland
Mitchell
350/SM465 Short Bed
Quick question
on a slave cylinder that is work properly as it should, should I be able to compress the boot without any kind of resistance? In simple terms should it feel hard to push if everything is working properly?
I know that if it leaks and you squeeze it the fluid will come out, thus giving me the assumption that it should have some "firmess" or "resistance" when I squeeze it.
Thanks
Kind of confused about your question. Yo mean the resistance of pushing the plunger in? By hand or by pedal?
Smitch320
The Southland
Mitchell
350/SM465 Short Bed
Sorry, plunger by hand.
While laid up under the truck I can "squeeze" the plunger by hand and nothing comes out, or there is like there is nothing in the plunger.
I've been told that if there is a leak, and you squeeze the plunger that dot 3 will come out, thus obvious you have a leak.
School me though, I don't really know.
Thanks
It should be fairly stiff, but you can push it back under normal circumstances. The fluid just goes up into the reservoir.
mick84
