Size brake lines coming from proportioning valve.
73desertstorm
waxahachie
james
Greetings all,
I snapped off the dang brake line going from the proportioning valve to the brake hose on the passenger side. I don’t want to buy a $95 entire kit. The fitting going into the proportioning valve is bigger than the fitting going into the brake hose. Can I just run to the parts store and replace the line?
Thank y’all,
What size goes into proportioning valve?
What size goes into the brake hose?
1973 gmc 2500 with a 454.
fast 99
Spokane, Washington
Some of those OEM lines had a special larger size fitting. If that's the case, make the line with a double flare tool. Remove the fitting from the old line and install on the new.
cpender
