Silverado trim help
My78truck
'Ol Holly
Virginia
Becky
C10 Silverado
5.7L
Can someone direct me to a good pinstriping tape that actually will stick? My Silverado trim has the black on it and some of the color has faded off. I thinking taping it off and repainting will be quite the ordeal. I ordered some penstripe off Amazon and it is junk - doesn't even stick even after I cleaned the application area with acetone.
Thanks
Tank6x2
Edmonton Alberta Canada
Kurt
C30
350, TH400.4:10 gears 2WD
Go to a decal shop, they’ll usually lead you in the right direction
3M, Trim Brite and Avery are all pretty good.
My78truck
'Ol Holly
Virginia
Becky
C10 Silverado
5.7L
Hello Fellow Square Body Peeps -
Still working on my '78, down to tailgate, spraying on bedliner, and exterior trim - just getting around to the trim :confused:.
Question #1 - My trim has oxidized - no surprise there for a 44 year old truck. I would really appreciate some expert advice on how to bring the luster back to my trim and keep it looking nice.
Question #2 - I started this thread asking about trim pinstripe. After further investigating, at some point there was black pinstripe placed over the original painted black stripe in it. If I decided to paint it, how do i prep and what do i use to paint it. Or........should I just use a quality pinstripe and if so, what width? I measured the stripe to be 3/8", but I cannot find quality 5/8"........any suggestions??
Thanks for the help as always.
Auburn, Washington
The trim is aluminum if I'm not mistaken. Question is, is it anodized? I believe so.
There's a thread about tailgate bands, above. That will likely be what you want to do. But I'd first try polishing it with compound and a rotary ball/pad.
Note I tried sanding off anodizing once....DON'T! It just messed the piece up.
mtbadbob
Montana
Bob
V20
Try using a very fine Scotchbrite pad first, then some Never Dull on the aluminum
If you want to paint the inset color again, just mask it off, lightly scuff it with a scotchbrite pad, then spray it.
Applying WD-40 to the anodized aluminum trim will make it look much better, but it doesn't last long.
mick84
