Should I replace this tailgate handle / can it be changed
All that and still no pix. :supergay:
i posted some in original post, but sureeeeee
heres some more
heres the OTHER tailgate, the one i did not use. yes handlel looks okay but the tailgate is like pierced on the back and its kinked enough to be flimsy esp as a tailgate. and the bottom is more rotton where it rolls and dirt gets up in. and the lever got easier with lube but it feels like the kink has caused some binding, and i dont wanna pry it open for a handle thats not much better than my other, with a good reason to think the back panel is the only thing holding it together lol
heres the one im working with. again. old photo is the same one, just before i painted it john deere yellow.
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10, 99 Silverado
I understand why you would see it that way, but the tailgate isnt rusting out, its not perfect either, but its a mechanical device with parts, of which a piece has received damage. The tailgate still functions as a tailgate and safely supports the load of me and tools sitting on it, which is more weight than i will need it to support in its function. The bed is also solid minus one support in the forward part of the bed, so for 0 dollars I have a very functional trailer, and less than 100 in switching from split rims to some regular rims/modern radials(already had, will be putting trailer tires on eventually), upgraded the topper(cap, camper, etc whatever people call it), pulled axle shafts to make it handle better on the road, fixed its dangerous safety chains situation, and threw some paint on the whole thing to shine the turd for a little while, at least not be so trashy in how it clashes. If you count the temporary taillights and the replacement of the vent tube + r and r i WILL be doing, its about 250 in the end for a mostly purpose built, but very multi functional trailer that will do a lot of work for me and served to help me learn more about things i find interest in, better understand 14 bolts, and better understand tailgates. I also learned a bunch with pexi, but thats all side-stuff.
I am aware I have a lot of junk.
I am aware its a lot of scrap iron, some good bit of brass, copper.
But I am UNaware of what it all is/was/can be, and if i were to go through it all rn, and decide on current knowledge, I would have thrown away my free, functional tailgate, perfectly fine manifolds, an oil cooler adapter, perfectly useable body panels(some quite literally mint, some rusty but strutcturally good, 4 rust free fenderwells, loads of driveshafts, an OE jack, a decent 1965 or so impala grille, countless pieces of flat stock, square tubing, carb cleaners, useable square body parts, and etc. That list is just my quick ones i can name, but there is more, because what ive learned is that my grandpa had a pattern for things he discarded, and it wasnt a pile is scrap or if its disregarded its junk, it was a complex system that only can be interpreted by his brain, because there is literal junk inside while good, useable and meant to be kept things are in piles outside the shed getting rusty..
Never claimed he was logical. Lol. He was a different one. But ive learned I cant throw it away unless its clearly scrap(Like a hacked up core support so it stacks nice, cut with a torch) or just a burned out refrigerator. And a large portion of what ive got left to learn is from square bodies, hes only rebuilt, destroyed, owned, parted out, worked on, etc like at least 10 by my estimation, if parts were good and he could use it, he kept. if bad but worth for a core charge, kept, bent or rusty/stilll functional, he sent it.
And in all, I enjoy this. It may sound like heartache but if I didnt want any of this i would list it on fb to come pick it clean, 2k bucks, but i dont want to do that nor will I. But I got a lot of quite literal junk to sift through to find what to keep, what to toss, and ive got trailers to fix up because where else is this scrap gonna go haha. But i also have nothing-to-me things that i know are mostly junk, but have a place in someones heart. they will be sold, mostly for parts to someone elses dreams. hope it helps them.
But i object to the label of junk if it works, it is not in fear of failure(think rod knock that gets bad), is still functional in its original or applied purpose, and is good at what it does.
So, this tailgate. Works like any tailgate, and its not binding up or unable to do its task(simple task) and I also didnt have to buy it, and by using it, its not rotting away in a pile. Now, there is my concern of the handle. Ive never been inside a tailgate or have experience with more than 4 tailgates, so the play and kinked aspect makes me think its not doing well, but because it works smoothly, my gut reaction is the metal is fatigued on the handle from being bent to ****, and they make new handles. but ive also never bought a tailgate handle/installed, so i need to evaluate if i should be buying a 100+ dollar tailgate or a 20 dollar handle and the labor of installing the handle.
Because this trailer holds trash and makes ilfrequent trips to the dump, where the tailgate sees being used only to open the rear opening, where i pull it off and place it in my truck bed so i can dispose of my trash at the incinerator, i dont think the thing needs a tailgate purchased new or used, because if it can be fixed for less(potentially none, assuming the handle is fine and im just overthinking) and without having to repaint my tailgate, just a handle, i think my inexpensive project that helps me a lot in my daily life is worth 25 dollars for the experience and knowledge and function it may return.
I know you southerners think that rust means its not working or its of no value, but i could say the same thing about UV and heat damage, poor driving skills, mud(@Vbb199 no offense, but you guys have way more mud), dust, or busch light.
But the nice part is, there is a level of rust that can be remedied on most applications and there is usually ways to repair things back to 100% or to avoid rust all together, and we can all do that together and share our tips and tricks, impart knowledge, and help keep quality american relics alive as a testament to their quality and impact they have had.
And lets be real, paladin, a normal girl my age would see any of our trucks and think its absolute trash, no stops. It doesnt have modern annoyances or meet the standard of the average person, so what value could they possibly have? Its just junk, new trucks get better MPG and have better statistical performance, so therefore you and i just drive our squares to the scrap yard and walk to the dealer.
If you are on this form, youve accepted that there is a reason to, for some personal or selfless, keep puting money, time, effort, and headache despite the readily available options of today.
I justify fixing my rusty problematic things because its monetarily wise to spend less money fixing what i already have(esp if i have the parts, tools to do so) and cause myself grief and learn new things rather than spend more money, learn nothing, and accomplish the same goal, and potentially miss out on something enjoyable.
You have found working on your truck at some point relaxing or enjoyable, yes? Even if you haveent, it has brought you happiness or done good work for you, yes? @Paladin
The real square is the good times we had along the way.
I will keep Learning, I will keep fixing, and I will attempt to best-use my resources, and i will clean up my property so its nice to look at, and i will enjoy doing it. Had my box been shot or the frame rotted, etc, then there would be a calculated choice to make, potentially a different route, but the enjoyable, informational, and cost effective option suits me, so i choose square body.
ITS A WAY OF LIFE
Hey hey hey!
Mud washes off, rust don't :Nonono:
Paladin
"Teufelshunde"
Wichita Falls, Texas
C30 Silverado Crew Cab Dually
ITS A WAY OF LIFE
OK @AuroraGirl , first let me say that my post was in no way an attack at you!!!! You should be commended for wanting to save and make use of any thing which may be of use to you and also for your desire to learn which is an awesome thing in itself. I myself am just super OCD when it comes to things just sitting and laying around taking up space for which I have little to no use of, I make such items disappear quickly. I personally can not stand clutter, trash, and junk!!! Might be a throwback from my time in the Marine Corps. I smoke but on my entire property you will not find one cigarette butt on the ground. I have had people come around for some reason or another and see them throw a butt down in my yard. First time I will pick it up and put it in my pocket, if they don't learn from sight then if it happens again I remind them that I don't go to their house and throw my trash down in their yard and they need to just leave. I'm very OCD like that. Anyway I'm starting to get windy and in the end whatever I or anyone else thinks about what you do with your treasures is irrelevant. So in closing I shall say to you, KEEP ON KEEPING ON, YOU GO GIRL!!!!:cheers: :smokin::happy160:
Oh no i wasn't angry, think of it as 2am passion lol. Although my brain doesn't require the neat or order(kinda wish it did sometimes) it's not all choice. If I started out fresh and this was all my making, it would keep organized easier. But taking over such a stockpile is.. difficult
Smitty69
