Shorter Accelerator Cable?
nvrenuf
Mobile, Al.
I thought I’d seen this discuss before but I can’t find any threads.
I’d like a shorter accelerator cable, my current (‘91 Blazer) cable (per Rockauto) is 29.25” long and forces me to twist a loop into it to fit my carb.
I see a ‘78 K10 cable should be 25.5” long and a ‘74 K10 cable should be 24.25” long. Has anyone made this swap? I’m curious if there are any issues with the cable connecting to the pedal assembly.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
I'd bet they are the same. The pedal floor mounts are the same, even 67-72 has the same floor mount pattern but with a mechanical linkage.
I'd have to check to be sure though.
idahovette
Firefighter
Weiser Idaho
Perry
K20-K10
Saw a Pioneer brand..I think, that was 19.5 inches long..same look as our cables ........#CA8468......Summit site, about $21
What bracket are you using? I am using a 2 barrel bracket on my 4 barrel and it does this same thing
nvrenuf
Mobile, Al.
Currently I’m using a qjet with the factory bracket (original 454 stuff) but I’ll be changing the carb and using an aftermarket adjustable bracket soon.
I found that my 91 cable is 29.25” w/ eyelet at the carb, a 78 is 25.25” w/ eyelet and a 75 is 24.25” w/ ball & socket. (Blazer applications)
That said, I’m going to try one from a K10 w/ 6.2 diesel that’s about 21” long. I’ll report back on the fit.
82sbshortbed
Why like that?
SE Texas
Doug
1500 shortbed, 1500 longbed
@82sbshortbed had one made, maybe he can post up the info for the shop that made it for him
The shop is the name of the shop. Lol
He used the Mr gasket throttle cable. Idk the part number off hand but, you can Google it.
duncan_schawalder
