hey there, would anyone happen to have part numbers for bilstien shocks for an 1987 gmc v2500 with a 4 inch lift?? mine has old skyjacker shocks but can't find a number to cross reference them need for front and rear . Thanks
Good luck man….
I tried getting a set of 5100s for a 4” lift K20. Researched part numbers and confirmed and they were too short and the bushings were too small (and pressed in so tight I’d have had to beat up the shock to remove and order new or run smaller bolts on the front iirc.
I couldn’t find the right length. Iirc couldn’t get a longer extended length.
Never mind the bushings issue.
I found the right length and bolts size in one of the high $ Bilstein models I believe. But I returned the 5100s and got some cooler looking Skyjacker shocks that fit for half the price of the 5100s.
I think ORD offered replacement bushings the right bolt diameter but whatever.
And the steering stabilizer didn’t fit either. But it was a direct fit for the Ram 2500 so I put it on that truck. Lol
