Frankenchevy
Proverbs 16:18
- Jan 3, 2018
- USA
- Jeremy
- Square
- CUCV
- Small
For the spring or airbags?I like this idea. Is there any kits out there at least for the mounting points that would make me the set up you’re talking about?
This is what I run on my trucks:
Daystar Universal Air Bag Cradles for 6" bags - KU09140BK
DESCRIPTION Daystar KU09140BK air bag cradles allow maximum rear suspension travel on vehicles equipped with suspension air bags. The unique design of this product will eliminate any worry of damaging your air bags while off-roading or any other activity that would normally over-extend the...
daystarproducts.com
Top bracket/airbag attaches on the frame side of the truck as normal. The bottom of the bag doesn’t attach on the axle side as it normally would. This cradle attaches to the axle side bracket. It cradles the bag under load. But allows separation under droop.
If you are referring to the flip kit for the springs, there are several kits. Look at ORD for starters. Converts your rear spring shackle from a tension shackle to a compression shackle. It’ll allow you to run a flatter spring. Other option to achieve this in part or whole, is a lift block. You can run a combination of both in the rear, but no blocks in the front.
For the front you can get custom leafs which will be about $1000 for the pair. Others have run tuff country EZ rides and liked them. Either way, a 6” lift spring will have quite a bit of curvature and not flex as easily as a 2-4” lift spring.
