Shocks for the front with 1 coil cut
pmayojr
NC
Perry
I'm trying to figure out what to do about the shock travel on the front of my 86 c10. I've cut one coil and it rides great until I hit a certain bridge where I live. It bounces bad.
Are there shock extenders for the front or lowered shocks?
DREAMER
Baytown, tx
Dreamer
High Sierra
I'd just get new shocks. One coil doesn't make enough difference to justify a shorter shock
pmayojr
NC
Perry
The shocks I have are brand new. Is there a stiffer shock maybe?
jt1200r
Huntingtown,MD
Jeff
r10
4.3/th400/3.08
do you check your alignment after cutting the springs
pmayojr
NC
Perry
Yes I had it aligned. I work at a dealership so its stupid not to do it. it wasn't out bad at all.
J Knight
Baytown TX
82 Chevy
350ci
I don't think its the shocks, did you cut out the front bumpstop mount off the lower control arm?
pmayojr
NC
Perry
I didn't. It looked like it would have enough clearance to not hit for normal everyday driving. Do you think its hitting?
J Knight
Baytown TX
82 Chevy
350ci
With one coil cut which is about a 2in drop, yes.
pmayojr
NC
Perry
Ok. Thanks for the help. I will be cutting them out in about an hour.
pmayojr
NC
Perry
That fixed the problem. Thanks again
Good job :waytogo:
Kipps5000
