series1 or 2
kramdua
fredericksburg,
mark
va
hi,
i have a 1984 c10. in the lmc parts catalog page 196 which is dome lights. they list a series 1 and a series 2. since mine is a 1984 it list either series. i emailed lmc truck and they can't answer the question. i don't have the old dome light so i can't just look at the picture.
thanks,
mark :shrug:
chengny
Early 1984 housing measures 2 1/8" x 4 3/8". Late 1984-1987 housing measures 2 1/2" x 4 5/8".
I know that isn't much help, but check the positioning of the mounting holes. The old ones had the holes kind of in the corners:
And on the new style, the holes are centered along the side edges and closer to the middle:
Another hint is the bulb socket style - if the harness is still there and intact.
The older type used a bulb with a 2 pin twist-lock base:
The later version uses a tubular bulb:
The 1st series harness looked like this:
The 2nd series has two clips:
If you have to build a dome lamp from scratch - I suppose it would't matter which style you choose. If you do go that route, Classic has everything you'll need:
http://www.classicparts.com/Misc-Lamps/products/366/
IMHO - they provide a much better product than Long Motor. Although they don't generally even mention it, the parts they (Classic Parts) supply are often NOS and at very reasonable cost.
kramdua
fredericksburg,
mark
va
dome light
thanks so much
i did figure out the dome light by the position of the screws but i was wondering just wondering what the difference in the series was.
i do appreciate the info though with great pictures.
mark
Bigskygearhead
