SBC cam swap
devonrommel
CA
Devon
GMC Suburban K2500
Hey guys, I have an 83 K2500 suburban. Stock LT9 350/Sm465/3.73s.
I asked comp cams what RV type cam they recommend for my engine. They suggested this:
Grind Number:XE256H
Engine Family:Chevrolet 262-400 c.i. 8 Cylinder (1958-1998)
RPM Operating Range:1,000-5,200
Cam Type:Hydraulic Flat Tappet
Lifter Style:Hydraulic Flat Tappet
Camshaft Series:Xtreme Energy
Camshaft Gear Attachment:3-Bolt
Usage:Street/Performance
Valve Springs Required:Yes
Camshaft Material:Cast Iron
California Proposition 65:WARNING: Cancer and Reproductive Harm P65Warnings.ca.gov
Advertised Intake Duration:256
Advertised Exhaust Duration:268
Intake Duration at .050 Inch Lift:212
Exhaust Duration at .050 Inch Lift:218
Intake Valve Lift:0.447
Exhaust Valve Lift:0.454
Lobe Separation:110
Assembly Lubricant Included:Yes
Intake Centerline:106
Lobe Lift Intake:0.299
Lobe Lift Exhaust:0.304
My question is, what kind of gains can I expect from this? I'm trying to get more towing power on the cheap.
Sent from my SM-G960W using Tapatalk
cstew47
colombia
craig
In my experience, I have never seen a cam swap alone make a big performance increase. The cam is part of the system consisting of the carb size, head flow, torque converter stall speed and gear ratio. I wouldn't get your expectations too high for just the cam swap, although, that spec seems right for your truck.
75gmck25
Northern Virginia
Bruce
That 212/218 duration should work, although most references I've seen had a max of about 214 @ .050 duration with stock heads. If you use stock heads and a decent carburetor and intake manifold you should get a noticeable increase in power, but with this duration you are at about the best you can get with stock smog-era heads.
If you also swap to better flowing heads it will really help a lot. If you use aftermarket 64cc aluminum heads and thin head gaskets you can get the compression up about 1-1.2 points, and the aluminum heads will tolerate more ignition advance without pinging. Better flow, higher compression and more timing - it all adds up to quite a bit more power.
Hard
