Rochester Varajet II Carb adjustment
jtsd
SAN Diego
J
4.1L 250 Inline 6 cyl
hello,
Was wondering if anyone had any info on adjusting a 2 barrel Rochester varajet carburetor, my truck runs for a couple seconds after I kill the ignition and rattles the exhaust pretty good. Thinking I'm running rich or the engine is still running after I turn off the truck, I've heard this described as "deiseling" but had some trouble identifying the adjustment screws on the carb. Anyone know of any online links?
Thanks
CSFJ
You may want to check your timing before you go adjusting the carb.
74 Shortbed
Yes, check timing first thing... You should have something similar to this on the side of the carb facing the the valve cover, that adjust idle speed and closes the the throttle blade completely to stop after run, air mixture screw will be facing the front at the bottom, at least that's the way it is on mine..
jtsd
SAN Diego
J
Thanks for the replies, any recommendations for a good inexpensive timing light?
Thanks again
jtsd
SAN Diego
J
Got it, thanks for the recommendation!
K10noob182
