Right blinker acting weird
Goulet264
Canada
Vince
My right blinker in my dash turns on when I turn on my headlights, but not when I engage the blinker arm. Also when it turns on it just stays lit and doesn't blink.
The actual blinker itself works well, its just the light in the dash that is bothering.
Did this happen to anyone else?
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
When I doubt, check the grounds.
Check the bulb, make sure it’s the correct bulb. Make sure the socket is clean, add a little bulb grease to keep corrosion away.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
You're sure all of the turn signals are working properly? They usually stay lit if the lights arent working proper like a burnt signal filament.
Wallace6
Wyoming
Ray
Suburban
Mine does the same and my bulb is clearly not operating on both filaments
Goulet264
Canada
Vince
Yes they all do, its really on the dash
Previous owner was an amateur electrician and installed/"fixed" a lot of "issues" he found.
We pretty much had to rewire the entire back end of the truck.
justhorns
Denver
Lee
It was a bad ground on one front turn signal on my truck. Fixed sound and fixed the issue. My problem was exactly the same as yours.
sallyjeank10
