Reverse lights stay on
mrnapolean1
'87
R10
4.3 V6
Reverse lights stay on no matter what gear/gear selector the transmission is in.
I have a feeling its a switch somewhere and I would like to know where this is located....
For now I have removed the light bulbs for the reverse lights.....
Most likely the switch at the base of your steering column. IIRC, that is also the Park/Neutral Safety Switch. I think I'd start right there. It's like a half moon over the top of the steering column under the dash close to the firewall.
circuitguy
Elk Grove, CA
BIG-C
GMC 1/2 ton Stepside
Most likely is white if this helps.
Wow that's the first I heard of those staying on.
towjoe
Lafayette,IN
joe
78,80,81,81,86,88,89
K30's or V3500's
My m1028 reverse lights stay on all the time. I just shut off the service lights. Need to replace the reverse light switch, but since I never drive it, it's not high on list of things to do.
boarder421
