Reverse Light Issue
lwr199
Pennsylvania
Rich
5.7L
I have an 86 K10 with a reverse light problem. My reverse lights only work when holding the shifter between Reverse and Park. I read a couple forums about adjusting the neutral switch, but I am still having problems. When I started adjusting the switch, the adjustment was almost all the way counterclockwise. I can adjust the switch a couple clicks in Reverse and I can shift from every gear to Reverse and the lights work correctly, but as soon as I shift into Park the adjustment resets. I've adjust the switch in small increments from almost all the way counterclockwise to almost all the way clockwise and the switch seems to auto adjust when I place the transmission back in park. I've also never had any issues with starting the truck in Park or Neutral even though I've went through 90% of the switch adjustment. The ratcheting mechanism is strong on the switch, so I would be surprised if it is moving when I shift into Park. Does anyone have any insight into this? Should I replace the switch and if so anyone have any tips on removing the clip in style switch without creating a nightmare?
73c20jim
Tombstone, AZ
Just so I understand, where is the NSS you are adjusting?
lwr199
Pennsylvania
Rich
5.7L
Base of the steering column.
73c20jim
Tombstone, AZ
OK. How are you adjusting it?
73c20jim
Tombstone, AZ
I just realized you have an 86 and mine is a 73 and are probably different.
Mine required an .093 (I believe) drill bit to line up the NSS in neutral or park, placing the shifter in neutral or park (same for both). And then lining them up together.
Like I said, yours may be different.
lwr199
Pennsylvania
Rich
5.7L
I put the truck in reverse and move the ratcheting half moon shaped portion of the switch a couple clicks clockwise until the lights are working in reverse. Then I can shift back and forth from neutral, drive, 2nd, 1st, to reverse and the lights work as they should, but as soon as I shift into park and shift back in reverse the lights don't work again. It's as if the adjustment I make is reset when shifting into park. I have moved through most of the available adjustment using this procedure (one or two clicks at a time) and no matter where the position of the switch is in reverse with the lights working, if I shift into park and back into reverse the lights don't work unless i pull up on the shifter.
73c20jim
Tombstone, AZ
See my last post. Maybe the NSS is busted. Sorry, that's the best I can do. In Reference section, you can download manual on proper alignment procedure.
lwr199
Pennsylvania
Rich
5.7L
Thanks. I'll take a look at the reference library, I am trying to avoid replacing the switch because it is a clip in style that I'm going to have to fight with to remove, but I also leaning towards something being broken in the switch.
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
:welcome:
1977chevyc30
