RETRO-Mod: Jeep intermediate steering shaft
TPISly-C10
Boucherville QC Canada
Sly
C-10 shortbox
LQ4 6.0L
now i got to turn the upper collar 90 degrees and this will be ready to fit! :)
TPISly-C10
Sly
C-10 shortbox
LQ4 6.0L
ok everything work fine! moving 90 degrees upper mount was easy! :)
TPISly-C10
Sly
C-10 shortbox
LQ4 6.0L
all fit well only thing bugging me is the upper shaft is too short...yes can be mounted like that but with only one inch inside the lower tube is not very safe to let it run like this, yes you can tack weld it in place..but for me is not enough so I will lengthen the bottom tube 4 inches more for a good peace of mind! :)
TPISly-C10
Sly
C-10 shortbox
LQ4 6.0L
while waiting for the pieces to come back from welding, I will do the notch to retain the upper saft to the steering colum base in the right place! :)
HOTFOOT
northwest ct
michael
gmc k3500 srw
i think i'm gonna go for Astro solution! :D so tomorow its Hunting time! :)
Are yours out of a 2wd Astro van?
78C10BigTen
pennsylvannia
C10 BIG TEN
Do the astro shafts need to be adapted in anyway or bolt right in??
78C10BigTen
pennsylvannia
C10 BIG TEN
TPISly-C10
Sly
C-10 shortbox
LQ4 6.0L
now the weld and extended tube is done....just whait for the new lower column bearing kit to get here and all go back in place soon :)
TPISly-C10
Sly
C-10 shortbox
LQ4 6.0L
lower steering column bearing arrive today now ready to re-install! :)
TPISly-C10
Sly
C-10 shortbox
LQ4 6.0L
Bearing was not that bad just a crack on the bushing :) new one is in! ;)
TPISly-C10
Sly
C-10 shortbox
LQ4 6.0L
and then the modifie Astro shaft is in fit perfect in place and the drive is tighter not a big improve since i remove good OEM parts but for those who have wornout part is a big way to go! :) total cost: $40 for 2 used Astro shaft, $20 of welding= $60
Smitty69
