Resistor question
WFarm
Central Virginia
K5 Blazer
Getting ready to remove and paint the LH side inner fender on my 1975 Blazer and can’t determine what this large resistor is for. Truck came from factory with air, auto and 350 engine. Figure someone here knows for sure!
I believe that is the trailer brake power adjustment for an ancient brake setup. You could move that slider doohicky along the spring wire doohickys to adjust the amount of resistance. I've seen them, but never used them.
WFarm
Central Virginia
K5 Blazer
@bucket based on your lead I did a search for Vintage GMC electric brake resistor. BINGO! Mine is from a different manufacturer and not marked so obviously.
Not needed but looks cool, like something from Dr. Frankenstein’s laboratory. Might detail it and keep.
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
Trailer brake?
WFarm
Central Virginia
K5 Blazer
Yes, vintage variable trailer brake resistor. Don’t need it but too cool to not restore and reinstall. Proudly made in Michigan USA.
Hard
