Norwester
- Jul 3, 2015
- Battle Ground, WA
- David
- C-10
So I decided to tackle the problem I've been having with one turn signal not working. I finally found a broken wire and repaired it. No problem.
Not so fast......I checked all my rear lights and I have no brake lights. I figured the wiring was good between the lights so I suspected the brake light switch.
I got down there......what a job for an ole guy......and found the switch. I noticed that the plunger did not move back and forth when I actuated the brakes. It appeared to be all the way in, with no movement at all. I shot it with some silicone spray but I'm not expecting it to work.
I looked at pictures online and it looks like the plunger comes out a bit..maybe a 1/4 inch or so?
Am I right in determining that this switch is bad?
If bad, can somebody outline the best way to get to that switch and how to remove what is an apparently very difficult clip? Would removing the lower dash panel and dropping the column help?
Hate to think I've been driving around with no brake lights. Yowsa!
