When I'm plate adapter I go to metal by the foot and buy an aluminum stock piece about like what I'll picture. Usually 10.00 or less. Then I buy some counter sunk allens which I'll list also. Take a Varijet base gasket set it the plate and trace it. Set a weber gasket on the plate, center the throttle bores and trace it too. Take an appropriate size hole saw and cut your throttle bores. Drill your weber pattern bolt holes 5/16ths tap drill size. Drill your varijet bolts holes,11/32nds. Now drill the same varijet holes again just deep enough and big enough for your countersink screws to set just under flush. Tap your bolt holes 5/16ths to bolt your weber down. If your metal place is like metal by the foot you can probably find a scrap real close to the diamension you need to keep your cutting to a minimum. To cut length and width,pick your poison. Jigsaw,circular saw,band saw,sawzall. Take a varijet base gasket with you. All diamensions and fasteners I gave you will need to verify. I am assuming your manifold uses 5/16ths hardware abd don't honestly know base diamensions on a Varijet. But I used to put the 2 bbl Holley/ Weber on everything. You should have under 20.00 wrapped up in materials
