Removing paint and "polishing" it while maintaining patina?
TPISly-C10
Boucherville QC Canada
Sly
C-10 shortbox
LQ4 6.0L
Cab looks fine, you could probably just rattlecan the bed to match the front. White is the easiest color to spray paint, hides imperfections real well and never looks "stripey" (unless you do a ******* terrible job). Spray paint usually doesn't look as good as a real paint job obviously, but since the white on your cab is old and faded they'll probably match up perfectly, without wasting a bunch of time and money trying to artificially "patina" your truck and making yourself look like some Cali douche poser in the process lol
i buy a cheap spray gun and i tink that do the job! :D
TPISly-C10
Sly
C-10 shortbox
LQ4 6.0L
curiosely the primer color match the rest! lolll maybe i just have to spray a satin clear over it? a work in progress! :)
Raybo135
Arvada, Colorado
Raymond
K10 Silverado
Thanks! I really love it. A lot of little things to do. Tune-up next, temp gauge isn't reading right, and flatten the hood. lol
I just picked up the temp wheels, while I sand and paint the oem ones.
Sent from my SM-N960U1 using Tapatalk
How are you going to go about flattening the hood? I have a little bend in mine and it bugs me. I tried propping it open and pressing down on it. Didn't work though.
Sent from my SM-G960U using Tapatalk
78C10BigTen
pennsylvannia
C10 BIG TEN
The common hood crease at the crumple point??? Mine has that too.
Raybo135
Arvada, Colorado
Raymond
K10 Silverado
My next step is to use a hydraulic jack between the garage door and the hood while it is propped open. Wish me luck. I hope I don't bend it the other way.
US
Jake
I'm planning to use big c clamps and some 2x4s on both side and work it slowly back straight.
Doesn't have to be perfect but should get it close.
Raybo135
Arvada, Colorado
Raymond
K10 Silverado
I put lmc braces on it but theyre only for before it creases. Whoever gets theirs straight let me know how you did it.
I will let you know how I do when I try my method. Then I'm going to put the braces on it so it stays flat!
US
Jake
Mine already has the braces on it. [emoji849] They just didn't lube the coils/hinge, but rest of maintenance was done. [emoji2369]
But will do. I just need motivation.
78C10BigTen
pennsylvannia
C10 BIG TEN
My truck already had the hood crease on the passenger side when i bought it. Ive sprayed the hell outta the hinges and it closes better but i usually stand on the pass side and put my arm down the hood, elbow twords windshield and hand twords nose and push down first.
I've used a block of wood and a very large dead-blow hammer... you basically just smash it back down, lol. Once you do that, it's imperative that you weld bracing to the underside of the hood so it doesn't bend again.
Raybo135
Arvada, Colorado
Raymond
K10 Silverado
I will try that next. But with my luck I'll miss the wood and smash my hood and put a big dent in it. LOL.
US
Jake
Haha if you guys are just hitting it with a hammer, I'm just going to go stand on it. That will do the trick. [emoji23]
Charkmapman
