Rear window removal
Kirk
Nashville, TM
What is the best/easiest way to remove the rear window on a 73?
The rubber still looks pretty good, not cracked or anything.
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
flat chisel about 1" wide, and work the gasket through the opening in the cab out from the inside.
the rubber is H shaped, tucking the inner leg that the cab metal goes into back through the opening the window will fall right out.
get good at it, the R&I will only take about 7 minutes... don't ask how i know.
Hip 2 be square
Depends on if it's a pick-up or a Blazer...
Takes a bit more than 7 minutes on a Blazer.
Rene
I just took mine to the local glass place in town :) That was the easiest way for me to do it.
FenderBanger
