rear diff fluid color
marks86
Latham, NY
Mark
12v Cummins
Ive been having problems with my rear end lately so I pulled the cover and this was the color of the fluid. Also the drain magnet was 1/8 think with gunk/metal particles. This fluid has like 3000 miles on it. Something is clearing wrong here
image post
350runner
tx
Ceasar
Ouch!
Remember water mixes with oil and eventually makes acid hints the reason why things look so clean...
firebane
Calgary, AB
Curtis
You got some leaky seals.
marks86
Latham, NY
Mark
12v Cummins
They are brand new axle seals with 3000 miles on them
Moderator
Where is your breather vent mounted? It could be getting water splashed into it.
My '79 was getting water in the diff when it rained and the truck was parked. The bed floor was cut for a goosneck ball setup, water would drip off the underside of the bed floor, and onto the frame. Then the water would run off the edge of the frame and drip off the inner "C" area of the frame, right where the breather was mounted. It was just a trickle, but it turned the fluid milky.
CSFJ
What's the fluid capacity on your axle? if that's a normal size drain pan, that looks a little over filled, like some water got in somewhere.
MadOgre
NA
NA
NA
NA
NA
Gotta say water is the first thing that came to mind when I saw that pic as well. And water does a pretty ****** job of lubricating things.
Moderator Administrator
Yep, water got in somehow. Either thru the axle seals or the vent. The vent hose is supposed to be bolted to the bottom side of the bed with a 1 way check valve on it. That lets air out, but nothing else in. I'd check it.
As far as your rear end problems, see a proctologist.
marks86
Latham, NY
Mark
12v Cummins
Ive been planning on routing all my vents to the firewall, I guess this would be the best time to do so huh. Well it would at least eliminate one issue
don't let the picture fool you its a small drain pan
what the heck is a proctologist?
firebane
Calgary, AB
Curtis
Rear diff to firewall is far too long. You want a short run for your vent lines so they can breathe quickly.
And a proctologist .. well he puts a rubber glove on and inspects your rear differential.
asshole Dr.
350runner
tx
Ceasar
Strap up Goin in the rear! ugh!
MadOgre
NA
NA
NA
NA
NA
Should this be moved to the poop thread lol
dan86
