Rear brake issue after hydroboost
usar17
PA
K20 Silverado
TBI350/700r4/NP208
4-5 years ago I swapped in the hydroboost unit from a newer Chevy commercial van. I also swapped the brake proportioner out to an aftermarket disc/disc model. I have a 14bolt rear with disc brake conversation that has the 1/2 ton front discs.
Since doing all this I have had constant issues with my rear brakes; Fast wearing pads, easy rear lock up on rainy days, warped rotors, hot hubs, rear hop, and squeaking. Seems like I'm getting way too much pressure to the rear.
Did I miss something? Wrong proportioned valve? I plan to swap the rear out again for a newer 2000+ 14bolt axle this summer. IDK if the newer double calibers will do better.
Sent from my SM-G975U using Tapatalk
climb-101
montana
seth
c2 crew cab
6.0 LS
i just set my crew cab up with hydro brakes and i just ran new lines to the front 2 and one to the rear. In the back before the drop to the rear alxe i just added an after marker portioning valve so i can set the rears
usar17
PA
K20 Silverado
TBI350/700r4/NP208
I may need to add that. Thx
dvdswan
Port Orchard, WA
Dave
I could be wrong but a van may have a different proportioning valve than a truck
usar17
PA
K20 Silverado
TBI350/700r4/NP208
I only put in the hydroboost/master cylinder. The proportioner was an aftermarket for GM trucks
77 K20
Montana
K20 5" lift
HT383 fuel injected
I did the rear brake conversion, used a disc/disc master cylinder, used a disc/disc aftemarket combo(proportional) valve and had the same problems as you. Mine would even lock up on dry pavement. I too added an adjustable valve inline with the rear brakes. It isn't perfect, but a lot better than it was before.
usar17
PA
K20 Silverado
TBI350/700r4/NP208
Thanks! I figured I was just getting way too much pressure to the rear
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
Weird, mine never locks up, but I do feel like one of my rear rotors has a slight warp. It’s been there since before swapping to a disc-disc prop valve.
I’m going to get new rotors and rebuild my 14bff hubs with new bearings, races, etc. and hope it cures it.
usar17
PA
K20 Silverado
TBI350/700r4/NP208
Adding the manual proportion valve was gold! Fixed a lot of issues as I dialed it in. Thank you!!!
Swapping the front brake calipers to the 3/4 tons, is it as simple as just the caliper and the hose? Since I believe the banjo is different
TPISly-C10
Boucherville QC Canada
Sly
C-10 shortbox
LQ4 6.0L
usar17 i want to upgrade my oem 86 HB to a newer (2005) too can you tell me how you do it? since my old HB got a input master hole smaller i can't just swap the 2005 master and reservoir ( master too big wont fit small input hole from the old one) i see that newer HB got diffente mounting plate....can i swap my old mounting plate to the newer HB unit? thx for the help! :)
climb-101
montana
seth
c2 crew cab
6.0 LS
i pulled the plate off the newer master and made a new plate that mounts to the factory studs. I also cut the loop off the rod and threaded it since it needed to be longer to reach the stock pedal. I measured the distance from the pivot point to the mounting point for the rod on the truck i got the hydrobost from and made it the same also.
twzorek
