Radiator recommendations for 6.6l 400
76burb
texas
matt
suburban k20
I’ve got a pretty much bone stock 76 k20 suburban with the 400 engine. The radiator lip was broken so it won’t seal properly with a cap. Coolant was totally rusty when I bought it and the inside of the radiator is super rusty as well. The replacement size from Lmc is much smaller than the current radiator that is in it.
Current one is almost 3” wide and the replacement is listed as 1.5” wide. I’m guessing this truck has overheating problems in the past as there was no TStat installed in it.
Anyone have any recommendations for a good replacement radiator?
76burb
texas
matt
suburban k20
Any suggestions? Truck is running pretty hot with coolant coming out of the cap after driving for 10mins or so in traffic.
Rustisbest
Tennessee
6.1762844 liters
Stock replacement with HD cooling from your favorite parts place
fast 99
Spokane, Washington
An aluminum core replacement will work fine provided the fan, clutch, and shroud are intact, correct and working.
Don't get why people remove the stat. Coolant will move too fast for heat transfer. Even most race cars use a stat or restrictor. Install a 180 or 190 high quality stat. Economy lines are junk.
1979CJ7
