Radiator frame mounts
TrucksNJeeps
Ct
Dustin
Hi I’m looking to find out if I can use 82-87 radiator support frame mounts on my 76 k20 I knw that they are different but are they interchangeable mine is pretty bad and would like to replace while I’m changeing the core support and inner fenders
nvrenuf
Mobile, Al.
Iirc, the bracket itself is interchangeable between the years, HOWEVER, the hole for the body bushing is different. I can't remember which year range is bigger but the 73-80 vs 81+ have different size holes on the top surface of the bracket.
TrucksNJeeps
Ct
Dustin
Thank you I wish they just made the ones for my truck I also don’t want to spend 120 for used ones I’ll just spend the 30 for the lmc ones
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
:welcome:
Big Chip
Michigan
Kevin
C35
There's a good possibility you may be better off finding a different frame. Are the cab mount brackets ok? Spring perches, etc?
TrucksNJeeps
Ct
Dustin
The rest of the frame is pretty much perfect for whatever reason this was packed full of stuff and rotted out the other mount is almost perfect
Big Chip
Michigan
Kevin
C35
Junkyard time then!
TrucksNJeeps
Ct
Dustin
Unfortunately in ct they are rare to find in a junk yard and if you do they are rotted to the ground and very few ppl are parting out what I need around me eBay has a pair for 120 but I don’t need 2 and don’t want to drop 120 for 1 bracket
K201979
Winona, missouri
Hippie
350ci
I grew up in southington ct. u anywhere around there?
nvrenuf
Mobile, Al.
Buy some 3/16" plate and patch them?
TrucksNJeeps
Ct
Dustin
Yah Farmington and it’s to far gone to just plate the top the whole thing is paper thin I could re make the mount but I was just looking for something per made not trying to reinvent the wheel
K201979
Winona, missouri
Hippie
350ci
Cool. Usta go to the farmington river fishin for rainbow trout. And i can remember going to peoples forest which was farmington river. Not sure if any of that was in farmington, lol, but its gotta b close. Sorry for hyjackin ur thread n not being any help:33:
tkeefe
