Question about free wire of glow plug system 6.2l Diesel
German_fall_guy
Germany
Steffen
6.2 Diesel
My truck arrived yesterday and a got some questions about the truck. It is a 1984 K20 with 6.2l diesel engine.
in the first picture is a wire that comes out the glow plug wire loom on the driver side but all glow plugs are connected an no glow plug is missing a wire with connector also the coolant water sensor on the right side of the engine is no wire missing also. The color of the wire is green.
the secound picture shows glow plug controller switch but the middle bolt don’t have a wire. Is it correct? It looks like a bypass. It is a california truck but we have cold days right here. It the bypass good?!
So any help is welcome. Thx
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
I believe the extra wire is for the indicator light on the instrument panel.
They changed the whole relay and controller system in '85 so yours may be different than mine, but that's how mine is set up.
That solenoid does look like it's bypassed, which is not good. The glowplugs will not survive being on all the time. You're going to have to trace things and see what's up.
German_fall_guy
Germany
Steffen
6.2 Diesel
where is the connector located for the indicator light on cluster
Blue Ox
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
I'll have to look at mine tomorrow. My recollection is that the glow plugs/water in fuel lights have a separate harness that has it's own hole and grommet to pass through the firewall.
Blue Ox
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
I tried to trace it, but it all kind of disappears into the main harness. My best guess is it's a three wire harness that goes through the firewall just below the fuse block. If you have cruise control it's right next to that one.
Original
