Quadrajet Idle Mixing Screws
custodian
Catawba
William
C10, C30
5.3 LS, 350, 454
My idle mixing screws will not turn on my 86 C30 with a 454.
Is the carbureator on or off the car? Off the car, clean and dry I'd try hitting it with propane. On the car I'd use a soldering iron to apply heat use patience and more heat you know mixture screws only effect idle mixture. So push comes to shove leave them alone. Let it be rich at idle.
75gmck25
Northern Virginia
Bruce
Are you sure the anti-tamper plugs that cover the idle mixture screws have been removed? I believe there is a special drill bit that is designed to drill out the plugs, but mine had already been done before I bought the carburetor at a pick and pull.
custodian
Catawba
William
C10, C30
5.3 LS, 350, 454
I took the carb loose and sprayed them with PB Blaster. They turn now.
NikiFm
