Quadrajet adjustment mixture adjustment screws
Shank
Michigan
Bob
K-10
I need to adjust the mixture on my quadrajet. What bit do I need on my tool to fit the adjustment screws? TIA.
75gmck25
Northern Virginia
Bruce
Double D mixture adjustment tool works on the original mixture screws, or many carburetor parts stores will sell you new mixture screws with a standard flat tip screw head.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
Or you can remove them and carefully cut a slot in them for a common flare blade screwdriver.
Use a couple of pieces of scrap wood to protect the threads and tip, clamp them in a vice, and use a small cutoff wheel or hacksaw.
  • Like
Reactions: WFO
Sad Sack
Nebraska
Goober
C15
Get spares.
crowe-t
