Pull to the right?
Shalpass
Runaway Bay
Any ideas as to why the truck when running 40 or over it seems to want to pull to the right when brakes are applied...quicker more forceful brake pedal action to more of a pull
J Knight
Baytown TX
82 Chevy
350ci
Bad calipers and/or brake hoses.
Rule_So_Hard
Northern IL
Richard
k5
Really good chance its a seized caliper or the pins are crusty. My truck is have this same issue. The PO put a new passenger side caliper on it but not a drivers.....and I have a feeling he didn't bleed the brakes either.
I would start by removing both front wheels and inspecting both calipers. Comparing the two can often times give you a good idea of what's going on.
Shalpass
Runaway Bay
What I wouldn't give for a pair of Jack stands , nice Jack, and some ramps, that's what I need to do is pull the wheel and look to see what is going on behind those wheel s
flyboy1100
UsA
me
k1500
305, 700r4??, 3.42 gears
Mine is doing this too. Im thinking either steering box or rear brakes. My fronts are new and don't drag
79K10
Sacramento,ca
Ryan
350/th350
maybe its got the same problem as mine? ... found the shock like this last night ... lol
jt1200r
Huntingtown,MD
Jeff
r10
4.3/th400/3.08
check your left rear brake its not grabbing well.
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
You have a problem with the brakes not applying evenly, you could have kink in a brake line or a broken hose, it possibly could be the proportioning valve too not working correctly, and loose steering will only make it seem somewhat worse. But pulling one way or the other during heavy braking is most likely a brake problem
jastewart25
Louisiana
Julie
just had this issue!
i replaced hoses/calipers/pads
i am just learning so i will write exactly what the explanation from mech shop had on invoice:
front rotors checked out fine. fluid to rear axle seals leaking. removed axle and changed spider gears and true axle seals. changed both brake drums.
my truck brakes better than my 07 chevy now!
scottybaccus
Central Texas
Scotty
GMC R1500
I discovered a leaking brake fitting was causing mine to pull. It was a new line, replaced a couple of months earlier. Cold weather set in and shrinkage occurs, I suppose. A wrench resolved the issue.
derek87
