Project: 83 C30 Crew Cab Big Brown Turd
OldFatBald
Northern California
C30
Can you post a picture of the front spindles?
Spindles showed up in a pretty trashed box.
Pulled them out and one of them has a pretty good ding in it, I think that is where the grease seal is supposed to sit...
OldFatBald
Northern California
C30
What’s the srw rear end for?
Narrower axle width to make room for the wider tire setup and keeping them inside the fender wells?
What is the width difference between 14bolt srw/drw?
Yes sir, the dually rear end is 72" WMS to WMS (wheel mounting surface) and the SRW 14B is 67" WMS to WMS
This is supposed to allow the 22" Alcoas to tuck under the stock fenders using the 8x10 adapters. We will see what happens!
wanderinthru
Mid Point Route 66
Shakey
81, 70, 75, 84, 89
K 10, C 30, K 20
Maybe it's the picture, but that seal journal looks awful rough? Also looks cast? Personally I wouldnt want a seal to run on cast, much less rough cast. Or does the seal press to the spindle and run on the hub?
OldFatBald
Northern California
C30
I think that is just the photo not really showing it too well. It is a machined surface. I am more concerned with the big ol din in it.
OldFatBald
Northern California
C30
The new (old) SRW rear end will be getting new brakes and lines, cleaned up and maybe shot in epoxy prior to installation.
Craig 85
Nashville, TN
454/TH-400/NP205
Question, are you keeping those 11" drums or can they be changed out for the 13" from the Dana 70 that was in the truck? I don't know if the drums and backing plates are compatible from the 70 to the 14 FF, just throwing it out there. Here's a picture of the 13x3.5" I have on my K30 SRW for reference.
Big Chip
Michigan
Kevin
C35
Looks like you got belltech spindles so you’ll run into the same problem I have. I was hoping they would have sent you a different brand so I could see if the steering arm was lower in relation to the spindle.
OldFatBald
Northern California
C30
Grit Dog, yes the SRW is 67" vs the DRW 72" WMS to WMS (wheel mounting surface) and the idea is to keep the tires tucked under stock outer fenders. The bed fenders will be widened by 4"
OldFatBald
Northern California
C30
Big Chip, what problem did you have with the Bell Tech Spindles? And yes, mine are definitely Bell Techs.
OldFatBald
Northern California
C30
Well this showed up today and it's not even Christmas.
And yes I do make my kids hold up my purchases for my toys. That way I know that I will have photos of my kids.
Toyo 265/35-22s are on the way!
265/35-22 Toyos should be here in a day or two
OldFatBald
Northern California
C30
Question, are you keeping those 11" drums or can they be changed out for the 13" from the Dana 70 that was in the truck? I don't know if the drums and backing plates are compatible from the 70 to the 14 FF, just throwing it out there...
Sticking with the SRW drums, should be fine for what I'm doing, towing around a couple of German Shepherds and my wakeboard boat occasionally.
OldFatBald
Northern California
C30
My brown bed floor was pretty abused, so I picked this one up kinda locally.
Mounted it last night, it still sits a little low on the passenger's side.
I have a replacement front bed panel that I put in epoxy primer last night. Going to mount it this weekend and see if it pulls that side up some. The driver's side lines up quite well.
The C30's frame is is very good shape, I had a buddy check it and make some minor adjustments on his frame machine.
Big Chip
Michigan
Kevin
C35
You have to rotate the tie rod end 180° and install from the bottom up which means you can’t use stock alignment specs. There’s also a bump steer issue when you change the tie rod position. You can also see that a left turn creates an interference problem with the tie rod and pitman arm. To me it seems like the steering arm on the spindle is too high. It should be lower in relation to the spindle centerline. I was hoping you had a different brand so I could compare them.
crowe-t
