Power windows
Deerfarmer
Big Rock,IL.
Jeff
Silverado K10
My power windows were working in my 1977 K10 and then all of a sudden stopped working. All fuses are just fine what should be my next move before I decide to tear everything apart looking for a wire crack? How do I check the switches to see if they are fine? Confused....
Both windows don't work? They both quit the same time? If fuse is good may be the switch on the drivers door that controls both sides.
Deerfarmer
Big Rock,IL.
Jeff
Silverado K10
Correct, all of a sudden they both stopped working. I will check the drivers switch first then go from there. Thanks.
bobehud
St.Louis
Bob
91' with early 80's drivetrain
Suburban K3500
454 carbed
that switch is out there.Just replaced mine.AZ and O'Rielys among others,they refer to it as the gang switch.
FenderBanger
