Power mirrors?
apeman
Wenatchee, WA
Kevin
Anyone try to put power mirrors on an older square? If so, any direction on what may or may not work and still look somewhat "normal"?
Going to do power window/lock conversions on my 77 stepside and got to wondering about mirrors too.
CSFJ
You could use some off of one of the last square suburbans. Not sure which years, but they had a power mirror option. They dont look anything like the regular mirrors though.
Crispy
Carbon County, Pennsyltucky
Suburban V1500
Ugly SOB's. GMT400 style mirror with a square body base. I think they were available 1990 and 1991. Switch was located on the driver door panel which I think is different in a 77.
climb-101
montana
seth
c2 crew cab
6.0 LS
i have a set that is powered that are the same style. i thought about putting them on my truck. just have to figure out a switch for them. they are a little deeper on the mirror part (the black ring part) but other than that there the same size, both the top part and the mounting part. they have a 4 pin square plug.
nvrenuf
Mobile, Al.
That stainless set should be van mirrors.
Crispy
Suburban V1500
I was gonna say those mirrors look like either van mirrors or similar vintage Dodge mirrors. That connector looks like its from a Dodge to me.
Edit quick google tells me I'm wrong. Not a Dodge set but the plug is similar to later model Chrysler connectors
climb-101
montana
seth
c2 crew cab
6.0 LS
i think they are chevy van mirrors
apeman
Wenatchee, WA
Kevin
Thanks for the help so far! I've been a lurker for quite a while because I forgot my password, so I wasn't able to use the search function. After I made this post, I saw another one where someone adapted some Ramcharger mirrors including using heat strips and signal flashers. I don't need either of those, but between the van mirrors and the Ramcharger mirrors, I think I have some things to look for on my next trip to Pick 'N Pull!!
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
Yeah, those are GM Van mirrors, Dodge had similar mirrors but in black.
Tlambert
South Carolina
Tim
C10 Silverado
That black power mirror switch looks the same as the one used on 1st gen S10s with the small black power mirror option.
ajd89
Central Michigan
andrew
Heres a part number for the gm van mirrors if that helps at all. Found the post with the ram mirrors to those are pretty sweet!
Kenneth
germany
kenneth
V1500
Dodge Ram truck 80’s to early 90’s mirrors look like factory manual mirrors and mount in the original mount. You can buy new ones from places like A1Auto and just wire to Chevy switch.
mick84
